1965 Wagonaire dual exhaust question
  • Exhaust: 1965 Wagonaire dual exhaust question
    Need to put exhaust system on my 1965 Wagonaire. I want
    to put on a dual system. Single was only system available originally.
    Car is 283 V8, automatic, with sliding roof panel.
    Will Avanti down pipes from a Chevy engined Avanti fit
    my Wagonaire?
    Thank you
    Lt. Col. Jimmy Doolittle
    Absolutly! The frame is the same except the wagon has a slightly longer area behind the "X" member which would require either a longer pipe there or longer muffler. The rear of the system (from an Avanti)however will not work being the wagon has the exit for the exhaust behind the rear wheel opening.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
      Maybe tailpipes from a 1964 SW would work since the 289-4V was an option that year and the basic frame should be the same as a 1965-66 SW.
        Been talking to my pipe bender about this exhaust system, his main concern is with the down (header) pipes. Thanks to Warren, and his own thoughts about fitment of the Avanti / Chevrolet pipes. We are going ahead with trying a set, then going with the 63/64 Wagonaire dual system back. Thanks Larksedan.
        Hope it fits as he had informed me that the wye pipe is not available and he could only make the crossover pipe.
        Will keep you posted.
        Thanks
        Bill
          I put the '64 Wagonaire dual exhaust piping into my '65 Wagonaire. It required some custom bends from the manifolds to the exhaust pipes. I did not use a crossover pipe, so my car sounds more like a Studebaker than a Chevy. Unless you put a two pairs of flanges in a crossover pipe, the exhaust system cannot be removed once it's welded in place, so leaving out the crossover pipe made sense. The Cherry Bomb mufflers were fun for a few months, but then they seemed deafening, so I went back to stock mufflers.
          Gary Ash
          Dartmouth, Mass.
          ’41 Commander Land Cruiser
          '48 M5
          '65 Wagonaire Commander
          '63 Wagonaire Standard
            Thanks Gary, I needed some encouragement with my project!
            The only good pipe I had left was the extension pipe. The crossover, muffler, and tailpipe
            were toast.
            Thanks
            Bill
              When I had the exhaust made for my Avanti I asked for a crossover pipe, but had it made so there was a stub pipe from each side meeting in the middle with a slip joint. I fastened it with a stainless steel clamp that looked a bit like a tin can that surrounded the joint but didnt crush it in case it ever has to be removed for whatever reason. These clamps can be ordered through NAPA (not cheap but work great). I used these clamps on my 68 Le Mans when I installed its 3" exhaust on all the joints. Made the install & alignment that much easier.
              64 Zip Van
              66 Cruiser V-8 auto
                Thanks
                Bill
                The driver's side headpipe on dual exhaust cars can be a PITA due to little clearance between the steering drag link (reach rod) and the exhaust manifold outlet. I tried a vendor for said headpipes and was not happy; if I were to do it again, I'd use Don Simmons, word is his stuff fits properly.
                  Thanks
                  Bill
                  Bill
                  From your description, I believe that your pipe bender is going to try to fabricate the exhaust pipes.
                  I purchased a complete set from Don Simmons for my 83 Avanti. Which, by the way, fit perfectly and are 2 1/4". Here are a couple of shots to show you what you are trying to fab.
                  Drivers side set, note the head pipe.
                  Here it is installed.
                  [IMG][/IMG]
                  It looks close to the oil pan but there's more clearance than appears.
                  Good luck, Bob
                    My exhaust bender mentioned Don's name when we talked Avanti on the header pipes. Could be he will consult Don or just get the pipes from Don and fabricate the remainder? I don't know, hope it works.
                    Thanks for the pictures Bob, gives me a idea what I'm up against! Sure is tight in there!
                    Thank you
                    Bill
                      Thank you
                      Bill
                      Bill
                      Remember that Don only works in stainless. The decision on whom should build them is probably best left to your fabricator. He seems open to discussing the options with you.
                      Bob
                        You may need to convert your engine to a spin on filter to make the left Avanti head pipe work for you as the tall cartridge type filter can on 65-66 cars can be a problem when making duals. I had this problem on my 66 Cruiser. I had my duals custom made by an exhaust shop.
                        Frank van Doorn
                        Omaha, Ne.
                        1962 GT Hawk 289 4 speed
