V-8 water pump...
  • Cool/Heat: V-8 water pump...
    I've been told all Studebaker V-8 water pumps are the same...bnut I also see in catalogs that the Avanti has a special pump.
    Is there really a difference in the two?
    63 Avanti R1 2788
    1914 Stutz Bearcat
    (George Barris replica)
    Washington State
    Yes there is. Avanti pumps have ribs supporting the snout and a heavier bearing I believe.
      All V8 water pumps aren't the same. There is early versus late in which the shaft, seal and bearing are different as well as the hub. Then there is Standard V8 vs Avanti. The Avanti as Gunslinger pointed out and also different seal. Repo lionel stone variety had a problem with cavitation due to incorrect impellor and which caused over heating problems. New production has both improved bearing, seal and impellor. Rebuilt Superior Pump Exchange type also has improved bearing and seal using the original impellor when possible, but also using the correct replacement one.
      Bo
        A lot of new members do not know of the tremendous resource available to Studebaker owners.
        A lot of knowledge here on these pages regarding water pumps.
        http://www.studebaker-info.org/rjtechx3.html
        Robert Kapteyn
          Robert Kapteyn
          Am not a new member, but did not know. Now I do. Nice site! Thanks
            SO......now the $64,000. question: assuming all these pumps attach to any Stude V8 block...why not simply make one HD pump for everybody >>>? Price difference ?
              I wonder the same thing with these situations,use one cast for all.
              Joseph R. Zeiger
                One reason is that there is about a $10,00 difference in retail price between a regular and a heavy duty water pump at most of us vendors. We stock both, as some do not care to pay the extra money for a HD pump.
                Frank van Doorn
                Omaha, Ne.
                1962 GT Hawk 289 4 speed
                  What all of you seem to be forgetting is that an Avanti Pump is different than a Std. or H.D. V-8 pump.You cannot use a Std. Pump on an Avanti, because of the huge Water Pump Pulley and viscous drive that requires a longer center "nose" than Std. pumps.
                  I sell all THREE, and the only V-8 they do not ("fit" -using the term loosely) is 1951.
                    Not forgetting,simply did'nt know !
                    Joseph R. Zeiger
