4BBL Carburetor Questions. Help Me identify these carbs Please!
While it is a WCFB carburator as used on Studebakers 1955-62 it is hard to determine the application. This is determined by the numbers on the brass tag ususally attached to one of the screws. This tag seems to be missing. A picture of the trottle linkage hookup might help identify it. The numbers you show are just patent numbers I believe.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Accordingly to the parts manual, the following carbs were used on 62V:
WCFB-2829S-4 (STD & OD, no PCV)
WCFB-2830S-4 (AD, no PCV)
WCFB-3165S-4 (STD & OD, PCV)
WCFB-3166S-4 (AD, PCV)
WCFB-3422S-4 (STD & OD, no PCV)
WCFB-3423S-4 (AD, no PCV)
WCFB-3419S-4 (STD & OD, PCV)
WCFB-3420S-4 (AD, PCV)
You should find one of these numbers stamped somewhere (on the manifold flange usually).
Best of luck.sigpic
Originally posted by christophe View PostAccordingly to the parts manual, the following carbs were used on 62V:
Best of luck.
Yes, the additional air passed by the PVC coming in under the throttle blades will change the idle. Some WCFBs have enough air idle screw adjustment to work with some PVCs. It depends upon how much air your PVC valve passes at idle and how good your carb is.
jack vinesPackardV8
Originally posted by Mrs K Corbin View PostI've got one that won't idle..... and I have to keep the choke nearly closed to force it to run....
jack vinesPackardV8
