Powershift question
  • Powershift question
    I had put my Daytona convertible up on stands to adjust the shift linkage on the floor shifter and to change the speedometer pinion (another story). I decided to test the shifter by starting the car. With the wheels off the ground, I was surprised to notice that with the car in neutral the wheels would turn slowly (about 5mph on the speedometer). I also had to hold the brakes to put it in Park to keep from making bad noises. Is this normal on automatic transmissions?
    Museum R-4 engine
    Yes, as far as I know, it's normal. A little bit of stray contact btween the clutch plates, or between a band and a drum is enough to trun the wheels against zero resistance.
