Therehave been several posts lately about soaking cylinders to free-up stuck engines. One remady was mix of auto trans fluid and acetone. What is the ratio of the mix and wheredo our normaly find acetone.Thanks
Stuck engine
50/50 is the mix and you can find acetone at auto parts stores, big hardware stores, home improvement stores, paint stores.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
I thought it was to be mixed with brake fluid; not ATF. My memory fails me."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
Some people say mix the Acetone 50/50 with ATF, some say mix it with Power steering fluid. Pick your concoction. A hot sunny day may also help.My 1st car. "A TRANSTAR"
Starliner
Somewhere between Culture and Agriculture
in the Geographic center of Tennessee
I've always been afraid to try phosphoric acid. I could be wrong but I thought it converted iron oxide to iron phospate and was the active ingredient in rust converters, naval jelly, metal prep etc which stop the rusting process but don't "dissolve" rust- leaving you an engine that is still stuck by the iron phosphate. I also don't know how the acid would affect the other metals in the engine. I would love to hear from anybody with more knowledge on the subject, I have several engines that I believe would be good if I could get them unstuck. I've had some luck running engines that had been sitting for a long time- one since 1951- but I've never had any luck with the Stude V8 in 3 tries. Hardly a scientific sample but I have been able to unstick and run early hemis, nailheads a couple of hudson engines and a champ 6, probably just luck of the draw but I wonder if some engine designs/materials are more unstuckable than others.
