Hi everyone,
I recently put a carter WCD two barrel carb on the v8 commander that I built into my 55 truck.
From the first start up, the engine seemed to run fine on it.But now I'm experiencing problems
The engine uses fuel like I've never seen before. For some reason the mixture is far to rich and I can't seem to change it using the mixture / idle screws.
I've allready taken the carb apart twice and there seems to be nothing wrong. Floats and acc. pump seem te be ok.Gaskets seem to be fine.
I did some searching on the web and found out these carbs were also used on cadillac engines. Could it be that these carbs are just too big for the engine?
The carb has fixed squirters (I'm not sure if that's the right english word, sorry) that can't be replaced with smaller ones.
I hope you guys can advise on what to do? Maybe try a different carb. Which type should I go for?
Thanks a lot for all your help in advance guys!
Cheers John-Paul (Polle), The Netherlands, Europe!
