avanti tach renew
  • Electrical: avanti tach renew
    The tach on my Avanti didn't work so after troubleshooting I found the head didn't work. I took it apart and found that a wire was apparently broken in a tiny coil. I tried to find and repair it but after many attempts gave it up as hopeless in my hands. I managed to find another and got it working. The one I had was in decent shape and I hated the idea of tossing something so hard to find. It would at least fill the hole in a dash so I stuck it on the shelf. After a few years of having it sit there I finally decided to try to renew it. I wondered what was so special about it that it couldn't be rebuilt using parts from a modern tach.
    With the idea I had nothing to lose but time and money, I went out and bought a small (2 1/2 inch) plastic tach. I popped it open and checked out what I had to work with. The internals were small enough to fit inside the housing from the Avanti tach so I carefully pulled the needle and face and did some measuring. The pin the needle fitted on to was .007 too small but I figured I would come up with something. The face plate mounted differently too. Since it was an 8000 rpm tach it was going to read incorrectly so I attached it to an engine and hooked up my test equipment with tach and adjusted the guts to correct the reading.
    I started by building a frame to mount the guts into and then drilled a couple holes and tapped them to match the original 4-40 screws from the Avanti face.
    I drilled three more holes in the frame for the pin and the screws to mount the modern guts.
    On the back of the frame I drilled two holes to support the 2 screws that held the guts into the plastic housing.
    I then welded on 2 long #8 screws to mount the frame into the Avanti housing. I left the frame short and added 2 nuts on the mounting screws to adjust the distance of the face from the glass.
    In the back of the housing I drilled a 1/4 inch hole and added a rubber grommet for the wires to come through.
    All of this was done through trial and error over several days with many times mounting the guts and the faceplate for measurements and tweaking of the frame.
    Finally I started putting it together and adjusting the fit in the housing. I cut the ground wire inside the housing and grounded it to the frame. I removed the wire for the dash light and discarded it. That left 2 wires to thread through the grommet, One to go to the distributer side of the coil the other to go to the ignition switch.
    I put the 2 nuts and washers on the outside of the housing and tightened everthing up nice and square. Since it is no longer nessesary to insulate the studs (screws) coming through the housing I was allowed some wiggle room. I had to pull it apart again when I realized the frame was partially blocking the original dash lights from being inserted fully into the housing. I finally put it together for the last time and and mounted the faceplate and installed the modern needle to test it one last time. It all worked.
    I removed the modern needle and cut some short strands from a #14 copper wire. They were .004 inches so I mounted several of them in the Avanti needle and pressed it onto the pin. It took some pressure but slid up to where it needed to be.
    I then installed the glass and the chrome bezzle and carefully rolled the lip back over the housing.
    I guess I need to find another Avanti now that needs a tach...
    Rob
    Great job, give me your address and I will send mine over.
    pb
      pb
      Wow, you would send me your Avanti?
      Rob
        To: mapman,-----I love stories like this one! WELL DONE!!
          Yes, you can rebuild the car around the new tacho.
          pb
            Rob,
            Looks like you have a new career. Carefull though, you may move yourself to the next tax bracket.
            Cheers,
            Ken
              Great How-To! A couple questions:
              What manfr. and model number tach did you use?
              Did the tach have a "pot" adjustment for RPM? or, did you have to change components on the circuit board?
              Thanks again for the article and pic's, Paul TK
                Many years ago, I had the same problem with my '63 Avanti tach. I found that the wire in the coil was broken. I carefully unwound the coil, counting the number of turns. I salvaged some wire of the same diameter from a scrap transformer and rewound the coil with the same number of turns. After 30+ years, it's still working fine. Talk about a CASO!
                Jim Bradley
                Lake Monticello, VA
                '78 Avanti II
                  I used a small Equus tach from O'reily auto, it has a pot and a 4-6-8 switch which I left on 8 cyl.
                  Rob
                    Originally posted by spokejr View Post
                    Rob,
                    Cheers,
                    Ken
                    It must be cold and you're not thinking quickly...tachs bracket.
                      I don't call it that. If you priced a replacement tach and went , and then did that okay, you can call yourself a CASO. I file that under Mother Necessity, or a "...I wonder what happens if I did THIS?" moment.
