I have a '63 hawk, that year they used a bushing part of the year and a bearing the later part for the steering control arm. Without taking it apart how can I tell which one I have? it seemed to fail suddenly so that leads me to think it has a needle bearing.
bushing or bearing
I don't think you can tell without taking it at least partially apart.
If you remove the cotter pin and castle nut, save and keep track of the shims!.... you can see the bearing around the shaft then. The needle bearing will be thicker, and may even have part #'s showing. A bushing will be bronze and much thinner around the shaft.Bez Auto Alchemy
Mid 62, the torrington bearings were replaced with the bushings. 63 would have bushings unless they've been changed. Most Stude folk I've been around prefer the old style with the bearings. My 62 Daytona had bushings and I took the pin to machine shop and had it turned to fit the torringtons. My opinion, bearing will last much longer than bushings in this application. I've recently rebuilt front ends on 2 later model,64&66, and put bearings in them.
Just my opinion, don't hit me too hard,
Kim
