The small block ford is very light and very narrow. It is a great choice in my mind in many cases. Plus ever since carroll shelby put them in the cobra I have wanted one but so far not yet have I owned one.
51 Champ 350 conversion
Last edited by t walgamuth; 11-26-2012, 08:18 PM.Diesel loving, autocrossing, Coupe express loving, Grandpa Architect.
There is a guy on Ebay that has some kind of computerized plasma torch and all he makes is header flanges. You can buy the flanges from him and make what ever exit port type of header/exhaust manifold that you need for what ever transplant you plan to use. I built my own for Pinkie two deckades ago using Crane flanges that are NLA so I bought a set from him to make another as Pinkies are getting tired. The flanges look great.
Personally I am no fan of any automatic. It that 51 I would use the Bell and fivespeed trans from a Camero. For Pinkie I just use a top loader but being able to lay rubber say at 30 or 40 really make the kiddies in their toyotas shut up.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
Me? I have some photos of my interior, but right now it's in pieces as I'm cleaning it up and doing new upholstery. I can post some later if you'd like...Originally posted by toastervet View PostMy car looks like a 51 clone of yours...same color. Do you have some good pictures of your interior? Thankssigpic
1950 Commander Starlight Coupe
Regal Deluxe Trim
Automatic transmission
46k original miles, 4th Owner
Please do put up some pics. of your build. You are not the first to ask about that build. I have never done an engine swap on any Stude older than a 53, so I am no help there. But when you get around to the springs I know of a shop just East of Riverside and also one in Lynwood that will make you anything you need. And I almost forgot San Diego Spring.Last edited by Alan; 12-20-2012, 09:55 AM.
I have done what you are asking about. What I did was to graft a '68 Camaro front clip to the Stude frame, this gives you Chevy engine and trans mounts, a more modern suspension which affords disc brakes and power steering if you want it, (I did). The Camaro sub frame fits in between the stude frame rails like it as made for it. I used headers made for the first gen Camaro and they fit fine. I also installed a TH 400 transmission with a Gear Vendors overdrive. The engine has a Weiand 177 superchaerger as well as a Holley TBI fuel injection. The hood closes over all that without any bulges or holes. Here are a couple of photos of my car.As you can see I am not finished yet. The car will be primarily for the street so It also has A/C and other creature comforts.
Wow -- I can't believe it all fits under the stock hood!Originally posted by Larry R View PostI have done what you are asking about. What I did was to graft a '68 Camaro front clip to the Stude frame, this gives you Chevy engine and trans mounts, a more modern suspension which affords disc brakes and power steering if you want it, (I did). The Camaro sub frame fits in between the stude frame rails like it as made for it. I used headers made for the first gen Camaro and they fit fine. I also installed a TH 400 transmission with a Gear Vendors overdrive. The engine has a Weiand 177 superchaerger as well as a Holley TBI fuel injection. The hood closes over all that without any bulges or holes. Here are a couple of photos of my car. [ATTACH=CONFIG]19271[/ATTACH][ATTACH=CONFIG]19272[/ATTACH][ATTACH=CONFIG]19273[/ATTACH] As you can see I am not finished yet. The car will be primarily for the street so It also has A/C and other creature comforts.sigpic
Regal Deluxe Trim
