Carberator hold down technique
  • Carberator hold down technique
    Do the four nuts bolting the carb to the intake manifold use washers, lock washers& or flat washers? PO used none.
    I used flat washers, the reason being I can continue to tighten if I have gasket leaks. Lock washers have a limit.
    OK I lied....I'll do it again for the "right" car, I love the chase.....
    It is an addiction!
      What Joe said....
      Always use small (SAE) flat washers so you don't chew up the ears on the carb. You can still use a lock washer.
        Third vote for flat washers only.
        Flat then lock washers are ok too. Just be sure to put the flat washer on the carburetor first.
        Don't TIGHTEN carbs. with aluminum bases! Just past snug...as long as a good gasket is used is good.
          I don't get what you mean by this. Can you explain more? Seems to me both have (the same) limit.
          Bellingham, WA
            I have a new gasket between the carb and the intake manifold. Base of carberator seems to be an iron compound.
              Good eye....
              WCFB = White Cast Four Barrel
              AFB = Aluminum Four Barrel
                I always thought it was "Will Carter Four Barrel"
                http://www.442.com/oldsfaq/ofcrb.htm
                http://www.348-409.com/ab.html
                Bellingham, WA
                  Interesting....
                  More urban legends on my part?
                  Or, maybe it was Al Carter?
                  Beats me... I dunno...
                  I heard it that way from a Stude guy in 1969, so you know it has to be true and accurate[|)]
                    quote:Carter had been manufacturing the model WCFB four-barrel in the early Fifties, and General Motors began using the "William Carter Four Barrel" as standard equipment in 1952, with Packard picking this type of carburetor as its stock equipment choice in 1953, followed by Chrysler in 1954.
                    http://www.hemmings.com/mus/stories/..._feature8.html
                    quote:Because these "White Cast Four-Barrel" carburetors had jets and metering rods that were on the money, performance of the optional 270hp 283 was very good.
                    http://www.superchevy.com/features/t...rolet_history/
                    Well I'm confused.
                    David
                      You're confused?
                      I thought I was wrong, but that was a mistake
                      Well I'm confused.
                      David
                        My R1 AFB originally only had nuts, no washers.
