Will the 4 speed flywheel- from a 289 engine fit on to a 259 with 3 speed overdrive transmission?
Can I use the clutch and pressure plate from the 259 on the 289 fly wheel?
I am sure the flywheel and starter on the 289 are 12 volt as is the entire car. I want to keep it that way. I would just like to get the flywheel machined and ready to go so my swap goes as smooth as possible.
Beside starter flywheel (with same ring gear) anything else
I have what I think is the O/D cable the car has the 3 on the tree stub left on the steering column, I will be using a floor shifter.
I will need to determine if the O/D unit is a 6 cylinder and changer it out if is.
please let me know sooner than later so my swap to great running 259 3 speed overdrive goes smoothly. Thanks in advance for your help and advice.
Thanks again K-Hawk
Thanks again K-Hawk
