weep hole function on a water pump ????
  • weep hole function on a water pump ????
    What is the function of a weep hole ??.........brad
    To weep, of course.
    Seriously, it is to prevent any leakage past the mechanical seal from getting into the bearing assembly and destroying the bearings.
    If the seal has failed to the point that you notice leakage from the weep hole, it's time to replace/rebuild the water pump. So think of it as a failure indicator.
      Weeping a few drops a day is normal as is some rust streaking.
      JDP/Maryland
      64 Daytona HT/R2 clone
      64 GT R2
      63 GT R2
      63 Lark 2 door
      59 3E truck
      58 Starlight
      52 & 53 Starliner
      51 Commander
      JDP Maryland
        Make absolutely sure the weep hole is straight down when a water pump is installed. You would be surprised how easy it is to forget that.
        Museum R-4 engine
          Thank you for that trouble shooting tip.......Brad
          JDP/Maryland
          64 GT R2
          63 GT R2
          63 Lark 2 door
          59 3E truck
          58 Starlight
          52 & 53 Starliner
          51 Commander
