Adhere hood insulator
  • Adhere hood insulator
    I am having problems keeping the rear half of my hood insulator adhered to the hood. On hot days it droops loose, push it back up and it stays for awhile then same thing again.
    What works and where do I get it?
    Last time I do this,I promise
    It is an addiction!
    3m Super Trim Adhesive, pad in my Avanti up for a couple years now and it definitely gats hot in there(G)
    ErnieR
      ditto
      Tim K.
      '64 R2 GT Hawk
      Tim K.
      \'64 R2 GT Hawk
        I comes in a spray can. Spray both the pad and the hood. Let it tack up several minutes before you put the pad in place.
        Bellingham, WA
          ErnieR
          Make sure you get the SUPER Trim Adhesive. 3M makes three different strengths. I believe the number of the one you want is 8090.
          Skip Lackie
          Washington DC
          Skip Lackie
            I got it and will tape off the area and get started tonite... thanks guys!
            It is an addiction!
              And be careful. Once it touches the other surface, you won't be moving it again. After installing one I realized why so many of them are crooked in factory installations.
              Museum R-4 engine
                Cover the engine bay and fenders with a sheet, the stuff splatters like crazy.
                Tim K.
                '64 R2 GT Hawk
                Tim K.
                \'64 R2 GT Hawk
                  I can assure you the car will be protected, can I get a Trojan that large
                  It is an addiction!
                    I attached the insulater tonite, I used a plastic drop cloth tho protect the car along with masking tape. I followed the directions on the can and all appears well.
                    One thing I did that seemed to help alot was to cut a piece of the plastic(clear) slightly bigger than the pad and placing it over the glued pad. We raised the pad located it properly and then gently moved the plastic back a couple inches at a time. This allowed us to rub out any air pockets as we moved from the cowl back to the front grill. Straight as an arrow in perfect position. Hope it helps someone in the future.
                    OK I lied....I'll do it again for the "right" car, I love the chase.....
                    It is an addiction!
                      Good job, Joe.
                      Sorry to hear that you guys won't be coming down for the GA Meet. But with gas prices, I don't blame you. See ya at the next one!
                      quote:OK I lied....I'll do it again for the "right" car, I love the chase.....
                      Found a Super Lark?
                      Matthew Burnette
                      '59 Scotsman
                      '63 Daytona
                      Hazlehurst, GA
                      Cruising the Proving Ground Test Track
                        Matt keep an eye and an ear out for that "right car" for me
                        It is an addiction!
