Air filter for 57-60 4bbl air cleaner - FOUND!
  • Air filter for 57-60 4bbl air cleaner - FOUND!
    Some digging with the help of the NAPA manager turned up the perfect fit! NAPA 2050 is a glove fit replacement for Stude p/n# 1545986, for all 1957 - 1960 V8 with 4bbl (this is the air cleaner with the flat front stamped FRONT and the short snoot intake on driver's rear). The only other MFRs x-ref I can find for this is Wix 42050.
    Hope this helps some others who might be looking.
    Clark in San Diego
    '63 F2/Lark Standard
    Did you get the $50.00 one or the $120 one ? If it's the cheaper one, I suspect it came off a Studebaker truck or a very similar AMC unit. I'd look in the back of the filter book for one with the correct height and diameter. It was on a Studebaker, I bought it from a Studebaker vendor, but it still could be a mystery unit that was swapped at one point.
    JDP/Maryland
    64 Daytona HT/R2 clone
    64 GT R2
    63 GT R2
    63 Lark 2 door
    59 3E truck
    58 Starlight
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      I got the $50 one I've actually got a pic of this same air cleaner on a '58 Packard sedan, which jibes with what Nate's interchange list shows. The Lark part manual says they were used on '59 & '60 V8 cars.
      Clark in San Diego
        OK, I thought maybe it was just close to factory and fits, but off a brand X.
        JDP/Maryland
        64 GT R2
        63 GT R2
        63 Lark 2 door
        59 3E truck
        58 Starlight
        52 & 53 Starliner
        51 Commander
        JDP Maryland
          Nope, here's one on a '58 Clipper:
          Filter found! See the top of the post for info.
          Clark in San Diego
            I'd run an oil bath unit on Pete's 289 for years. It used the manual choke Stromberg WW that it had worn originally.
            In going in with the new engine recently, I chose to use a new Edelbrock and had to find an air filter that would work on it. While I didn't have any Stude 4bbl cleaners, I do have a couple off of mid-60s Ramblers and I selected one that had come off a 66 or 67 Ambassador. Since this 289 is a Full-Flo there wasn't a problem with oil filler pipe/filter mount clearance.
            It didn't have an element in it, but I figured it would be fairly easy to find one at NAPA. Poor guys there dragged out every mid-60s AMC element they showed for 4bbls and we never DID find THE exact replacement piece for the cannister I was using.
            I did finally settle for one that was perfect diameter-wise, but was about a half inch too short in height. Since I had some THICK felt sheet in the shop, I cut and glued a circle into the seat of the element and it works mighty fine now! I like having a "period" cannister rather than something chrome-plated that comes from JEGS.
            Miscreant adrift in
            the BerStuda Triangle
              My thought exactly! Mine came with a 10" generic chrome pancake [xx(] This air cleaner I can turn around backward and have the snoot face front for a not-quite-factory but all-Stude look!
              Clark in San Diego
