Power steering leak
  • Steering: Power steering leak
    I've had a leaking control valve for too long - finally tracked down the problem. One of the lines coming off the valve body is loose, it moves even though the nut is locked down solid.
    I know there isn't any gasket/washer in there, how do I get this thing to seal?
    If the flare nut is tight the flared part of the line could have a small crack in it, causing the leak you describe. If this is the case a new line is in order.
    Frank van Doorn
    Omaha, Ne.
    1962 GT Hawk 289 4 speed
      Looks like the hose tube seats are the likely culprit:
      http://www.stangerssite.com/CanIControlValve.html
