Carter AFB R1 Start Fuel Lack
  • Carter AFB R1 Start Fuel Lack
    When the engine's cold, I squirt 3 or 4 shots of gasoline into the front barrels of the carb from a small oil can. I then start it and it fires right up and runs fine thereafter. If I don't do this it just grinds away and never fires. I also see the glass fuel filter bowl that was full last night when I ran it is empty this morning. When the car used to start more easily, the fuel filter bowl would stay full for weeks between starts. I had the carb rebuilt recently. I recall the same problem before I had it rebuilt. I push the accelerator one time to the floor and release before trying to start. The fuel pump has been rebuilt. Both the gas and return lines are new. The gas tank was boiled and coated inside. There's probably some simple answer?
    remove the air cleaner.Check to see that your accelerator pump is working.Because you can dribble a little gas and it starts.that would appear to be the problem.
    63 Twin Supercharged Avanti
    64 Avanti R3w/NOS
    88LSC Avanti 350 Supercharged w/NOS
      When I park my Hawk warm and open the hood I will sometimes see the fuel bowl drain slowly and then as if by magic as the car cools it will siphon the gas back in. After about 4 days the bowl will be empty. If yours is empty before then, I'd say the little valves in the fuel pump need replacing.
      Tim K.
      '64 R2 GT Hawk
      Tim K.
      \'64 R2 GT Hawk
        What shape is the fuel pump in? If it's not close to new, it could have weak or faulty check valves that are allowing the fuel to be siphoned back to the tank. If it's the original Carter pump, those were prone to do that. Also check the rubber line back at the tank. The original line had the wire spring clamps. Use new fuel line with the worm drive clamps. Any rusty metal line could have a pin hole in it as well. Hope this helps.
        Dan Miller
        Atlanta, GA
          ...also, after several rebuilds, the casting on the carb float bowl becomes more porous and the fuel can evaporate from the bowl after a couple of days.
          Bellingham, WA
            Tim and Dan: You know it very well could be the two check valves. I replaced the little rubber washers around them when I rebuilt the pump (had to press out the valves, replace the washers and press the valves back in) but didn't thik about replacing the valves themselves. It's an original Carter R1 pump. Where can I get the valves? Thanks.
              Dan,
              The last ones I got, the valve, spring, and the rubber seal, came from one of the major rebuilders. (you know, the back door kind) Other than that kind of source, I'm not sure. Those don't come in pump rebuild kits for some reason [B)]. Mabe some one else will chime in with help.
              Dan Miller
              Atlanta, GA
                The valves dont even come in the kit anymore, they send you rivots.
                The rubber part you replaced IS the "valve". The mushroom is just a
                holder for the rubber disc.
                My "how to" tech article .. buried on page 30.[B)]
                http://www.studebakerdriversclub.com...?TOPIC_ID=5982
                Tom
                quote:Originally posted by ivorydan
                Tim and Dan: You know it very well could be the two check valves. I replaced the little rubber washers around them when I rebuilt the pump ..... Where can I get the valves? Thanks.
                  dave Thibeault has the correct kits
                    And, they are the same ones Tom got from S.I. There is only one manufacturer of the kits, AND it sure is not Carter!
                    Studebakers Northwest
                    Ferndale, WA
                      From what I understand from information I collected during my quest
                      to get the correct upper seal - Carter owns the copyright on the metal
                      part of the seal, and so SI and others can not sell that part. They
                      can only sell the rubber part of it, and that gets destroyed by the
                      spring/washer they are forced to use. Talk about lame.
                      Here is the correct seal prior to install :
                      Here is the seal you get in the kit (mine was torn when I got it) :
                      Tom
                        Yeah, that really IS lame [xx(], because ironically Carter has no intention of ever selling any repair parts for their fuel pumps. That is just typical of what happens when small companies get gobbled up by giant conglomerate Corps. they no longer care!
                        quote:Originally posted by sbca96
                        Talk about lame.
                        Ferndale, WA
