I have a window distrubitor on my V-8 289 Studebaker engine, distributor is off a 1964 Studebaker. Qusetion will the points for a V-6 or V-8 1964 Buick Skylark work? They are identical in all physical aspects. I guess are the question boils down to, are the condensors for the Buick V-6 or V-8 compatiable with Studebaker specs?
Delco points
I just put a modern Delco distributer cap, points, distributer wires and coil on my '61 Cruiser, and they work just fine-completely put an end to the shutting down and stalling at low speeds once the engine heats up. My car also has the Studebaker 289 V8 engine in it. I got the parts from Advance Auto, so they were pretty basic, and I'd think that the one for the Buick would also work with the Stude, but you might want to check the numbers by a parts catalog that cross-references different makes and models of car just to be sure.
pitbulllady
quote:Originally posted by bob40
Glad to hear your stalling gremlins are under control.
pitbulllady
GTTIM wrote -
quote:IIRC the Delco window distributor was only used in '61 (maybe '60?). If you took it off a '64, someone else put it there, not the factory.
Curt -
While there may be slight differences in the actual ratings of different condensors...they are all close enough that ANY normal points type condensor will work with no ill effects. I've tried several in my 54 Conestoga as an experiment (from a "no it won't type statement!). Of the 6 or 7 I tried...nothing noticable...idle, acceleration or crusing speeds. All worked just fine.
[/quote]
the starter has that sorta "lag" and that little noise(can't even begin to phonetically reproduce it, but if any of you have ever heard a tired starter, you know what I mean[/quote]
______________________________
Like a 'wheeze'?
Dwain G.
D 'N Q RACE ENGINES
quote:Originally posted by Mike Van Veghten
GTTIM wrote -
The shop manual indicates the Delco distributor with the window is #1110969. The manual says this was used in '60 only. I can't say if that is actually what happened.
Tim K.
'64 R2 GT HawkTim K.
\'64 R2 GT Hawk
You have to remember Mike...there were one heck of a lot of '60 V-8 Larks built, and a fair amount of '61's. All '60-'61 V-8 Larks, NO Hawks had the Delco Window Dist. And every Stude. guy knew that a distributor with a Chev. top end would be a good thing for parts availability even back in the 1970's! Not to mention ease of point adjustment. [^] Lot's of them were salvaged.
Not sure I buy that at all. There's way too many around for a one year distributor!! I'd bet it was from 61 or 62 "and newer".
Studebakers Northwest
Ferndale, WAStudeRich
