Many years ago (about 35 years), I rebuilt the 6 cylinder engine in my 1954 Champion (which I longer have...) I had the crankshaft journals turned .010. After the rebuild, the oil pressure was still very low, reaching only about 20 lbs at 40 mph. Tested it with an external oil pressure gauge and it was sill low. So I rebuilt it again. The journals and the bearings showed considerable wear in only a few months time. Took extra care to keep everything exra clean. Oil pressure was still low as it was previously. My Machinist suggested that perhaps Studebaker had 'surface hardened' the journals and that is what we should have done, but didn't.
I am rebuilding my first Studebaker engine since that time and am concerned about the hardness of the journal surfaces. This engine is a 1963 full-flow 289 V-8, non Jet-Thrust. The same machinist that did the machine work 35 years ago is the same machinist that is doing the work now. He said when he turned the crank (again to .010) he got lots of sparks and so the journals seemed to be of good steel. He remembers the problem we had with the 6 cylinder crankshaft. This is the first time the engine has been rebuilt, everything initially measured out from standard sizes, though well worn.
My question is, do we need to be concerned with the hardness of the journals after having turned the the bearing surfaces down .010? I don't want to have low oil pressure.
Thanks for everyone.
