Clear Coat Paint
  • Paint: Clear Coat Paint
    Researched the subject on the Forum. From what I gathered, if the clear coat is peeling off, the correct way to redo before new paint is to strip off the clearcoat and paint. Is that correct?
    That is certainly the best way but for sure you need to remove all of the clear as it will continue to deteriorate. If the base coat has no cracks and still looks good, you may not have to remove it all. If you do sand off the clear you must remember to keep it all straight and flat. This usually takes some skill.
    If you do decide to use paint stripper you will likely run into some filler here and there that must be delt with either by refilling or straightrening. The great thing about removing everything is that you will then find what is beneath and what the body really looks like. You will almost certainly have to do some repair work prior to priming and repainting.
    Good Luck.
    don
      A thorough block sanding to remove all the clear coat, followed by a good sealer should suffice. No need to strip off the paint if it is adhering well. Do you know how many coats of paint are already on the car?
        Three coats (original, two repaints) of paint are on the car. The paint under the clear coat is not cracking or peeling. The peeling clear coat is only on the flat surfaces (hood, roof, trunk). There is no clear coat peeling on the vertical surfaces. Does the clear coat need to be removed from those surfaces?
          If it were mine-and a nice driver, not a show car- I would block sand ALL the clear coat off and about 1 layer of paint with a long board (18") and some 180 grit, followed by a 240 grit block, then seal it, reblock with 400 wet and then prep for paint. The clear coat sands easily and usully doesn't load the sandpaper quickly. If all the paint layers are solid, you will have a nice, smooth (probably better than what the facory sent out) finish. If you're making a show car, it is time to strip it down to bare metal and start all over again.
            The danger you have is possibly too thick a base. With that much paint already on the car, before you do anything, go to an automotive paint jobber & ask them to measure the thickness of the paint you have already. It is measured in "mils". If the paint is allowed to be too thick, then from expantion & contraction, it cracks causing a "crows feet" condition. Whatever you do, clay & wax the car every 6 months. The wax is a protection from the U.V. rays the same as suntan lotion on your skin. Think about what you expose you car to on a daily basis. If we were exposed it wouldnt take any time at all to have a severe sunburn or worse, a cancer.
            60 Lark convertible V-8 auto
            61 Champ 1/2 ton 4 speed
            62 Champ 3/4 ton auto
            63 G.T. Hawk R-2,4 speed
            63 Avanti (2) R-1 auto
            64 Zip Van
            66 Cruiser V-8 auto
              Thanks for the guidance and advice and the clear coat and at least one coat of paint will be removed. I had wondered about the thickness of the previous three coats (which is four if the clear coat is counted) causing potential problems.
                Before you even start sanding; clean off all surface areas you'll be working on with a good quality automotive surface wax, grease & silicone remover. IF ...you don't do that FIRST, you could be sanding (embedding) contaminants right down into the remaining paint. Personally, I use "FinishMaster 300," but any automotive paint jobber will have something similar to offer you.
                Good Luck!!!
                  "Three coats (original, two repaints) of paint are on the car. The paint under the clear coat is not cracking or peeling. The peeling clear coat is only on the flat surfaces (hood, roof, trunk). There is no clear coat peeling on the vertical surfaces. Does the clear coat need to be removed from those surfaces?"
                  IF you have 3 "paint jobs" on it, you might as well strip it all off and start over. There is WAY too much paint on there, and anything you do other than stripping, will just add to the build up of material.
                  Not trying to ruin your day but, even if you paint it yourself, you'll spend about $1299 -$1500 in materials.
                  My Avanti is on it's 4th repaint, only 2 since I've owned it. The first time I blocked 80% of the first 2 paint jobs off, last time, I stripped it with a razor blade, and blocked it a bunch more. It now has minimal material on it.
                  Even being in the Collision Business, materials were in the $1200-$1500 range. Why take a chance on the paint failing in a few years or less?
                  Jim
                  their Memorials!
                    Looks like taking off all of the coats is needed to be done. Thanks
                      http://www.autobodystore.com/strip_&_paint.shtml
                      Patrick. (nibbs 53)
                        Patrick: Saved what you sent along with the other recommendations & comments. Thanks to all.
