How to solve a REALLY stuck clutch problem and bleed your brakes at the same time
  • #16
    Well, then I have a question.....
    I'm dropping a 1GZFE into a Toyota Supra, that I overnighted from Japan. Does it have the 4 or 6 bolt mains that the 1UZFE has, and what's a good recommendation for a Turbonetics Turbo, injectors, FMIC, and external wastegates, because I'm working on getting 600 hp out of this bad boy, like what my buddy is doing. I am also wondering about the tranny behind that engine, should I upgrade and should I put in a carbon fiber driveshaft and splurge on a TRD clutch disk. Also, is there anything I can do about the motor mounts and the shifting, squishy, body mounts underneath that came with the car? Should I go with the big 80mm throttle body because of the high output of the turbo? Also, I've seen the Youtube videos of these cars, and some of these cars tend to dance on the body mounts prior to leaving two tire marks on the road, and I figure I wanna get that fixed with some Delrin inserts to stop the "shifting".
    (100 percent sarchasm, although I have known a couple of Toyota techs a long time ago, who could tell you the wonders about the Toyota V8's and tell you all about the Prius's "hiccup").
    Sorry, I'm better than that, the cable driven throttle wire from our '85 Oldsmobile that's attached to the stock Studebaker linkage end, is designed to open and close as it should. No car goes anywhere if the engine races like that, or fails to stop.....
    • #17
      Yikes, this thread just keeps getting kookier
      Proud NON-CASO
      Romans 15:13
      Deuteronomy 31:6
      Proverbs 28:1
      Illegitimi non carborundum
      • #18
        I prefer the 5SFE, it gets better mileage!
        • #19
          To bring this topic back into context, I finished wiring in the overdrive back on the car, so for a little fun, I rolled the car over and spun it through the gears on the jackstands. So here' s Part 2 of this little endeavor, with overdrive engaged.....
