So I started in on replacing my king pin bushings, they are not as bad as I first thought but I'd rather do them now than wait until the king pin wears too much. Do I need a spreader to remove the upper pin? The manual is not clear about this, just says to remove the pin & bushings. Also, does anybody have the bushing press tools they'd like to sell or rent? I can make something, but if someone has them I'd rather not make them.
King pin removal question?
It is very important to take notes, measure, and use tools so you do not bend the a arms and stuff while re- installing items like the upper pins. I have the tools If you need them. hotwheels63r2@hotmail.com I have notes and pics from several good, bad, and ugly king pin and suspension jobs I have seen/ done. The trick is not to guess, do it right the first time. We have done a few and have a bitch'n set of tools.
My old shop teacher said , " the first fifty are the hardest" I wonder who has done that many 'round here. ?
Originally posted by Studebakercenteroforegon View PostIf you're not replacing the king pin itself you don't even have to disconnect it at the upper end.
Forget the zip ties,they won't stay. Borrow the tools from {S} order the complete kit,and do the whole job.You'll be much better off in the long run.. Do you have a shop manual? You need a spreader when you install the upper OUTER pins,and this is really NOT a job to do without a manual!
OOPS! Just reread and see you do have a manual.Oglesby,Il.
