Hawk Dash
  • Hawk Dash
    How does the aluminum panel come off the Hawk dash? Want to paint dash. Try and not bend the panel.[xx(]
    John Ratliff
    Got a weekend ? You need to pull all the gages, then the nuts on the back.
    JDP/Maryland
    64 Daytona HT/R2 clone
    63 GT R2
    63 Lark 2 door
    62 Gt Hawk
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    58 Starlight
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      Previous post neglected to mention removing the "nuts" for the switches and carefully bending the tabs on the speaker grille, and removing the metal switch identification "labels". Some panels have a small amount of "light adhesive", as does the glove box panel, which need to be carefully "worked". tempestan
        And not to mention undoing the clips and little bolts that hold the trim to the dash pad and removing the dash pad that is glued down!
        Wayen K.
        Libby, MT
        61 Hawk (Project)
          Wayen K.
          Libby, MT
          61 Hawk (Project)
          Thank God, I don't have a padded dash. Are you sure the I.D. tabs are fastened to the dash or just aluminum panel?
          John Ratliff
            Yes; their tabs are bent on the back of the fiberglass dash because they go on the ridge at the bottom of the dash, not the machine turned panel. You do have a '56-'61 type dash in that Power Hawk, not a '62-'64 right?
            Studebakers Northwest
            Ferndale, WA
              While we're on the subject, how much longer is the dash in a Hawk compared to the dash in my '54 LC? Has anyhone tried to install the Hawk dash into a non-wraparound sedan--if so, with what results?
              TIA
              John
