1961 Hawk-Gas Tank or Guage or ??
  • Fuel System: 1961 Hawk-Gas Tank or Guage or ??
    the guage shows full, gas cap is vented, the tank is full, the fuel pump has been replaced, but after the car runs for while or when the gugage gets to 1/2- the car stops runnng. Anyone have any ideas of why this happens.
    There could be rags or other trash in the fuel tank. A fuel filter or Carb. inlet screen if it has one, clogging up.
    Pinholes in the fuel line?
    If the Fuel Pump is the commonly available but not correct, Airtex type sold under many package (box) names, the ones with the laminated steel plates riveted together to form the actuator Lever, it could have failed, new or not.
    Bad Dist. Condensor? Bad Ignition Coil?
      thank you-
      need to find a qualifed mechanic in the phoenix area who can trouble shoot the possibities
        I don't know where your fuel line comes out of the tank but a friend of mines 53 the line came out of the lower edge of the tank the inner tube that is suppose to go down had came lose and turned over with it up the gas would go down to it and the car would stop. And he would still have gas in the tank. He dropped the tank and found it. Just a thought but I am probably wrong.
          Might give Russ Ware in Gilbert a call. He does quite a bit of Studebaker repair. He frequents this Forum.
          Frank van Doorn
          Omaha, Ne.
          1962 GT Hawk 289 4 speed
            Rusty Nut's Garage's Russ is good people; I sold him the 3spd/OD out of 1962 Lark for a Stude that he's building. I work at an auto repair shop in Tempe.
              thanks for the advice- everyone- will call Russ today.
                I wasnt able to find a contact number for him. Do you have it?
                  Russell Ware: four eight zero nine eight eight zero one five three or russellware at gmail dot com
                  Frank van Doorn
                  Omaha, Ne.
                    Thanks for the votes of confidence guys! Correction to contact info
                    Email is russelware at gmail
                    Phone 480 two zero nine nine three two eight
                    53 2R6 289 5SpdOD (driver)
                    57 SH (project)
                    60 Lark VIII 2dr sd (driver)
                      Sorry Russ I got that phone number out of the SDC roster so I guess it is no longer good. I am guilty of putting one too many L's in your e-mail though <G>
                      Thanks for correcting my screw up. Hope you guys get together.
                      Frank van Doorn
                      Omaha, Ne.
                        No worries Frank that was my old # I'll see if I can get that # updated thru SDC
                        57 SH (project)
                          Is the bottom of the gas tank dented up/in?
                          60V-L6 - 60 Lark convertible
                            not to my knowledge-
                            someone today thought I shouldcheck out the coil.
                            going to try to find time thursday to call russ
