Curiosity Question
  • Rear Axle: Curiosity Question
    Why do a lot of Studebaker owners replace the Dana rear axle with a Ford when they are repowering the car with an implant drivetrain ? Thanks, Dan
    To CarcrosswrdDan,----------- The Dana 44 is an excellent axle that's been around for a long time. The center section was used in the Dodge Viper V-10 sports car. But many Hot Rodders like the Ford 9"
      Narrower track (for bigger wheels and tires). Easier to change ratio. A less expensive way to get flanged axles.
      Jerry Forrester
      Forrester's Chrome
      Douglasville, Georgia
        Rear axle curiosity question
        My guess would be because of the weakness at the outer end of the tapered axles and also the pain in the a.. dealing with a puller when you need to work on (or even inspect) the brakes.
        '62 GT Hawk (4 speed, A/C, Power steering - running and DRIVING!)
          I'll bet a lot has to do with following the crowd. This is the most mentioned rear axle with rodders and becomes the one to have, needed or not.
            I think if we had the actual numbers, we may find that more Members with "Performance Studes." switch to a '65-'66 Stude. Flanged Axle Dana 44 with TT, or the Fairborn Studebaker/Moser Flanged Axle conversion Kit for the durability and strength.
