Exterior door handle 47-52 car
  • Exterior door handle 47-52 car
    Wondering how to get the 2 pieces apart. My springs are bad, and I already have a replacements. There is a large rivet that holds the handle in the main piece, looks like its in a brass bushing.
    Surely you don't have to destroy the pin to remove it? I am hoping they are threaded or some little un-seen trick exists.
    Dan
    52 hardtop
    www.studebakerhardtop.com
    Dan,
    When I did my 52, I had the same problem. I ground off the "peened over" part of the rivet, took it all apart, got new springs from Tractor Supply (local hardware) then took the old rivet (brass if I remember right) and drilled and tapped a hole in it 8-32 maybe it was 10-32 used a small washer and loctite and fixed the handle. I used the original rivet because it was the correct size and length.
    Jim
    their Memorials!
      To clear up my stupid question - It looked like a 2 piece pin & bushing but it was an illusion. Just one brass pin with a head on one ended and peened over on the other.
      Was able to knock it out, and reuse it.
      Dan
      52 hardtop
        I,for one, appreciate the update after you solved the problem. I knew that many years ago I repaired one of my handles with a hardware store spring stocked for garden shears(fit perfectly), but I could not remember the details. I guess I was not curious enough to pull one of my handles, but I didn't remember the repair being hard to do.
        1952 Champion Starlight since October,1971. 1962 Daytona
        since May, 2007.Searcy,Arkansas
