57 SC w/ 4 bbl Carb
  • 57 SC w/ 4 bbl Carb
    I have a 57 Supercharger from a GH and am thinking about putting it on my E38 truck. However, I also am considering switching the 2bbl for a Edelbrock 4bbl at the same time. Anyone out there done this?
    Thanks
    Dan White
    64 R1 GT
    64 R2 GT
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    I've seen a lot of apps, using your VS unit and a carb bonnet from a GT Hawk for an original AFB, or a Procharger style bonnet for a new AFB. The VS used the original air intake elbow and a K&N cone filter.
    Bob Johnstone
    64 GT Hawk (K7)
    1970 Avanti (R3)
      Here's a couple pics from a few years back..
      http://www.studebaker-info.org/vs57xCKa.jpg
      http://www.studebaker-info.org/vs57xCKb.jpg
      Bob Johnstone
      64 GT Hawk (K7)
      1970 Avanti (R3)
        You may have a problem "clocking" the blower to match the R2 bonnet since the early blowers do not have the extra tapped holes to rotate the back half.
        JDP/Maryland
        66 Sports sedan
        64 Daytona HT/R2 clone
        64 Daytona R2
        63 GT R2
        63 Lark 2 door
        62 Gt Hawk
        62 Lark 2 door
        60 Lark HT-60Hawk
        59 3E truck
        58 Starlight
        52 & 53 Starliner
        51 Commander
        JDP Maryland
          Dan; where are you going to get a sealed Edelbrock? I think I would use an R3 pressure box!
          Studebakers Northwest
          Ferndale, WA
            If you are using a VS-57 McCulloch, it's "clockable" in 10 degree increments. Some positions may put the bolts that hold it together in positions where they interfere with the Golden Hawk mounting brcket. It's possible to countersink the bolt.
            The SN-60 Paxton's, made for Studebaker Avanti's or Lark's and Hawk's with the R2, have only the mounting holes for their intended application; and aren't as clockable. Serial #'s start with "MS" for Avanti's, and "ML" for Lark's/Hawk's. Their mounting holes are in different locations.
            Mike M.
              It's a lot easier if you use the Lark/Hawk R 2 water manifold and supercharger bracket as the Golden Hawk set up doesn't adapt itself very well when trying to rotate the blower as the mounting holes has some interference. Not something that can't be solved but more difficult.
              This is something I ran into when putting a supercharger on my E28 hauler. I moved the radiator forward some and the crank pulley would not fit in the "V" part of the frame but was easily notched for clearance.
              Ted
              Thanks
              Dan White
              64 R1 GT
              64 R2 GT
                Thanks for correcting my on clocking the early blowers and explaining that only the later Studebaker blowers can't be clocked. I guess I ran into the bolts hitting the mount issue when I tried to add a 4 barrel back in the day and my memory got hazy.
                JDP/Maryland
                63 GT R2
                63 Lark 2 door
                62 Gt Hawk
                62 Lark 2 door
                60 Lark HT-60Hawk
                59 3E truck
                58 Starlight
                52 & 53 Starliner
                51 Commander
                JDP Maryland
                  JDP/Maryland
                  63 GT R2
                  63 Lark 2 door
                  62 Gt Hawk
                  62 Lark 2 door
                  60 Lark HT-60Hawk
                  59 3E truck
                  58 Starlight
                  52 & 53 Starliner
                  51 Commander
                  JDP Maryland
                    Thanks guys for the inputs!
                    Dan White
                    64 R1 GT
                    64 R2 GT
                    Dan White
                    64 R1 GT
                    64 R2 GT
                    58 C Cab
                      Ted,
                      Wasn't it you who suggested making a 4-bbl pressure box out of a Dutch Oven style cooking pot?[:0][}]
                      Miscreant adrift in
                      the BerStuda Triangle
