Temperature gage equivalent
  • Speedo / Tach / Gauges: Temperature gage equivalent
    I have a 1950 2R5 pickup. It is converted to 12 volts. I want to replace my inoperable capillary tube temperature gage with an electric one. Does anybody know what gage unit to get that will look the same in the dash.
    Thanks
    Norm
    I think nothing is going to look perfect in those wide horizontal bezels, but something like a '59 Lark would function, but without trying it I have no way of knowing if it will FIT.
    The very best method that I would probably use is an NOS 6 Volt Truck Electric Temp. Gauge with a Volt-A-Drop unit.
      You can have the old one fixed for a fair price, even if the tube and bulb are shot or missing. You will need the adaptor that screws into the block. Call The Temperature Gauge Guy:
      Roy Martin
      172 Laurel Hill Drive
      So. Burlington VT 05403
      802-862-6374.
      Gary Ash
      Dartmouth, Mass.
      ’41 Commander Land Cruiser
      '48 M5
      '65 Wagonaire Commander
      '63 Wagonaire Standard
        If I use the 6 volt temp gage with a Volt-A-Drop, does the 12 volt sensor presently in the back of the 63 259 engine block work or do I need to get a different sensor? It is hard to access so I'd just as soon not have to replace the sensor.
          Yes you need a 6 volt sender, but it is not a difficult thing to change.
          If the sender is too hard to remove because of bad engine mounts or some other reason, you remove the cylinder head rear end cap that it is mounted on instead.
            I was very successful in splicing a bulb from one gauge I bought off ebay onto my existing gauge. And you can't beat the reliability of the old school gauge, even works when the power is off... I think the procedure is on the DC pages.
            1948 M15A-20 Flatbed Truck Rescue
            See rescue progress here on this blog:
            http://studem15a-20.blogspot.com/
              Roy Martin
              802-862-6374.
              Gary, This guy can fix a water temp gauge that the tube piece is cut?
              My gauge had the tube/cable/wire cut off, but I have both ends. Just missing a section of the tube {I know they can not splice the tube back together, but I have the sender end and the gauge end}.
              Is it very expensive?
              Thanks, Kelly
              PS: This is in my '49 C-cab
