So,
It snowed last night and today's inspection cancelled 'cuz he didn't want me to inspect the roof if I couldn't see the entire surface and he didn't want to pay for me to make a return trip to the home 25 miles away after the snow has melted off the roof. Oh well.
While I'm sitting here dinking around in my office today, I decided to start an off-the-top-of-my-head list of the proper colors used on the P.H. I've been sitting here going through hundreds of photos (modern color and black and white original shop manuals) and trying to compile a list. It ain't been easy.
Hoping some of the more experienced stude brethren can look this list over and tell me if they spot any errors here. Please disregard the body color schemes. I found all of that on the Packard Club site:
Model: Packard Hawk
Year Manufactured: 1958
Body Style: 2dr. Coupe
Engine: 289 V8 (Supercharged)
Body Color Scheme
Body Colors: xxx, xxx, xxx, xxx, xxx, xxx, xxx, xxx, xxx, xxx
Trim Colors: xxx, xxx, xxx, xxx, xxx, xxx, xxx,
Factory combinations: xxx/xxx, xxx/xxx, xxx/xxx, xxx/xxx, xxx/xxx, xxx/xxx
Chassis Color Scheme
Chassis color: Chassis black (matte)
Body to chassis bolts: zinc phosphate
Steering:
Upper and Lower control arm shafts: Raw forged steel
Upper and lower control arm shaft bolts: Zinc phosphate plated
Inner shaft bushings - top and bottom: Bolts and washer are cadmium plated
Upper and lower control arms: Chassis black (matte)
Upper and lower control arm bushings: Chassis black (matte)
Steering knuckles - Upper and Lower: Chassis black (matte)
Steering knuckle - kingpin: Raw cast iron
Coil Springs: Chassis black (matte)
Stabilizer bar: Chassis black (matte)
Stabilizer link bolts: Cadmium plated
Tie rods and ends: Chassis black w/zinc phosphate bolts
Bell crank and lever: Chassis black (matte) Nut is zinc phosphat coated
Shock absorbers: Chassis black (matte)
Brakes Color Scheme
Master cylinder: Raw iron
Master cylinder reservoir cover: Chassis black (matte) (??)
Brake pedals/levers: Chassis black (matte)
Backer plates: Chassis black (matte)
Brake drums: Chassis black (matte)
Brake lines - steel: Chassis black (??)
Brake lines - flex: Black rubber w/cadmium plated ends
E brake pivot draw arm, bolt and clinch: Cadmium plated
Gas Tank Color Scheme
Tank: Chassis black (matte)
Tank bolts and washers: zinc phosphate coated
Drive Train
Bell housing: Raw metal
Bell housing bolts: zinc phospate coated
Transmission: Raw metal
Driveshaft - Chassis black (matte)
U-joints - Raw metal
Axle & Differential housing: Chassis black (matte)
Differential Cover: Raw metal
Rear Suspension
Rear swing arms: Chassis black (matte)
Swing arm bolts: Cadmium plated
Spring shakles: Chassis black (matte)
Shackle bolts: Cadmium plated (??)
Leaf Springs: Chassis black (matte)
Rear shocks: Chassis black (matte)
Shock bolts - top and bottom: Cadmium plated
Engine Compartment
Air cleaner bonnet: Gloss black
Generator bracket and adjustment arm: Engine black (matte)
Generator body: Engine black (matte)
Generator ends: Raw aluminum
Generator pulley and can cooler: Cadmium plated
Generator pivot bolt: zinc phosphate coated
Generator adjustment bolt and washer: Cadmium plated
Supercharger housing: Engine black (semi-gloss)
Supercharger input shaft pulley: Engine black (semi-gloss) (or Cadmium plated???)
Supercharger idler arm: Aluminum paint - semi-gloss
Supercharger idler pulley: Engine black - semi-gloss
Supercharger bracket: Aluminum paint - semi-gloss
Supercharger spring: Raw metal (zinc phosphate ??)
Water pump housing: Aluminum paint - semi-gloss
Water pump: ???
Water pump pulley: Engine black - semi-gloss
Cooling fan: Engine black - semi-gloss
Power steering pump and reservoir: Engine black (semi-gloss)
Oil filter flange: Raw aluminum
Oil filler/breather cap: Engine black (semi-gloss)
Oil filler tube: Aluminum paint - semi-gloss
Rocker arm covers: Engine black (semi-gloss)
Rocker arm cover studs: Cadmium plated
Rocker arm cover nuts: Cadmium plated
Valley cover: Engine black (semi-gloss)
Valley cover bolts: Cadmium plated
Engine block and heads: (Aluminum paint - semi-gloss)
Intake manifold: Aluminum paint - semi-gloss
Intake manifold bolts: Zinc phosphate coated
Oil pan: Aluminum paint - semi-gloss
Crankshaft pulley: Engine black - semi-gloss
Battery base: Dipped in black liquid rubber and cured
Battery hold-down: Dipped in black liquid rubber and cured
Battery hold-down bolts: Zinc phosphate coated
Battery hold-down nut and washers: Cadmium plated
Battery hold-down-to-body bracket: Cadmium plated
Air chamber cover: Raw aluminum (clear coated??)
Coil: Gloss black
Coil bracket and bolts: Cadmium plated
Brake booster can: Black semi-gloss
Booster mounting bracket: Black semi-gloss
Booster can bolts: Cadmium plated
Radiator hose clamps: Cadmium plated
Heater hose spring clamps: Zinc phosphate coated
Heater hose-to-body brackets: Cadmium plated
Just wondering how difficult it would be to produce a document that lists the "proper" colors for various components on various models of Studebakers by year. Perhaps it's already been done.
The reason I ask is that on the Packard Club site they had a page dedicated to various colors and they list them by model and year. Since it's posted to their site, I'm guessing that they consider those, by consensus, to be the proper colors for those components. For us '57 and '58 owners it's a little iffy over there though. They mostly only show stuff up through '56 'cuz they consider the '57 and '58's to be red-headed step-childred due to their coming out of the Studebaker plant instead of the Packard plant in Detroit.
Could such lists not be compiled by consensus here by SDC members, and then posted to the site, so that newbies don't have to continually ask the same questions?
Model: Packard Hawk
Body Color Scheme
Steering:
Brakes Color Scheme
Drive Train
Rear Suspension
Engine Compartment
Water pump: ???
Coil: Gloss black
