Wireing harnes and front windhield for my 58 Hawk,
  • Electrical: Wireing harnes and front windhield for my 58 Hawk,
    I need to replace my wireing harness and front windshield on my 58 hawk. Where is a good place to obtain these from. Also,any tips you would share to help me get these changed out.Iv've been off the forum for a while,back surgery and recuperating slowly. My floor pans are coming along still, had to be able to bend again,, Mike..
    http://www.studebakerswest.net/
    http://www.autoglassclassics.com/
    Brad Johnson,
    '56 Sky Hawk in process
      Thanks, got some good info from both sites.
        What type of Butyl tape/filler should I use on my 58 Hawk wndshield? Where in the front windshield frame should it be put,or should I completely surround the glass before it goes in. This is a first for me, would appreciate your input.. Where is a good source for the install, and does anyone have any threads or links showing removal/ installation of hawk front windshield. Thanks...
          Pay an autoglass installer with many years experience to install it and you'll be miles ahead. And some shops can still obtain the glass for you.
          KURTRUK
            Buying my windshield on payday ,already have the new windsheild rubber gasket bought it from stude vender,I hope it it fits,am looking for an old time Glass installer like you suggested. Will let you know how it turns out. Thanks for the heads up..
              Hawkman,
              Where are you located? And YES pay a professional to install it! as Kurtruk mentioned, "you'll be miles and money ahead" Studebakers West wiring harnesses are spot on, they go by the original color codes and you can follow the wiring diagram in the shop manual. I used them on my 52 Commander and my Avanti.
              Jim
              their Memorials!
                Also, understand what a wiring harness does and does not include. Whatever is bundled in the main loom. Not a lot of the "Extras" under the dash--like the wire for the clock or radio or glovebox light. Those go beyond the main harness.
                KURTRUK
                  I'm just outside Spokane Washington.. Mike..
                    Thanks,its always those little things that you learn after you buy it,. Has anyone ever tried an aftermarket hot rod type harness?? My Hawk was hot rodded in the 60's so it will never be correct in the word,but it is all will be all studebaker. I have a problerm with the harnesses heating up,and to not have fuses in the systems is against all I was every taught.That you always had fused circuits to protect your studebakers. I really don't want to finish this and loose it do to a fire..
                      I've done a couple of hot rods with kits like this http://rebelwire.com/rebel-wire-prod...at=Wire%20Kits. All the wires are labeled and the installation is pretty straight forward. Be sure to solder your connections to save future issues.
                      They are also less expensive than custom harnesses.
                      There a many posts if you search but I'll save you some work with the above link.
                      Bob
                        Glad your feeling better. Take it easy!!!
                          Bob good information on wiring harness. I added it to my list of site. I noticed a harness called or for sunbeam alpine tiger. My 1st running car was a 69 sunbeam alpine gt coupe . Good memories it has been quite a while since I thought about that car.
                            Also take a look at EZ Wire. Good price if you check around and a nice product which is quite easy to install. Also had very good help from their techs when needed. I used their 21 circuit harness which gives one some extra circuits which might be useful at a later time. I have a new one waiting to go into the new project.
                              wiring harness for 58 hawk/windshield
                              Thanks for the sites for the harnesses and EZ Wire,will be checking them out appreciate the info , and Bob ,I will pull up that site .Soldering everything is the bestway.Simple is better,and good tech support is what you need when you run into a problem and there a phone call away. K-Hawk hope your project is coming along well.Will let you know on those sites..
