Question' dial indicating a 6 cyl?
  • Engine: Question' dial indicating a 6 cyl?
    This is a first for me and got to thinking about it so I am asking.
    I am getting ready to replace the dead 185 (replacement engine) in my wife's 1951 Starlight coupe. It is a 6 cyl with an automatic behind it. The car has a worn out 185 reolacement engine in it and I am replacing it with a rebuilt original 1951 Champion engine.
    The rebuilt engine was a manual trans ( i know i have to shorten or swap the flywheel bolts).
    The question is on the engine coming out of the car has a steel plate with dowel (?) pins in it. And the plate bolts to the block. I am aware of having to dial indicate V/8's
    Can the plate be swapped from the old engine to the rebuilt engine and be in alignment? Or, do I still have to dial indicate the trans to the engine?
    George King
    Grants Pass, Oregon
    64 Station Wagon with fixed roof (Canadian Car)
    66 Station Wagon with fixed roof. Project car, complete For Sale...
    64 Wagonaire sliding roof South Bend car. For Sale...
    63 GT Hawk
    51 Champion Starlight Coupe For Sale...
    George: You must dial-indicate sixes as well as V8s.
    In this case, it is even more important because the car will have an automatic transmission. Automatic-transmission cars are more susceptible to block alignment issues because the flex plates are relatively fragile.
    Poor alignment in a manual-transmission car will cause problems, especially over time, but will not leave you dead on the road with a busted flex plare or an unusual noise you can't find no matter what you do (a cracked flex plate still driving the car.) BP
      Bob, Thank you for your prompt reply.
      If I remove the steel plate that has the alingment pins (dowels) from the old engine to the new engine, it seems to me that I should not have to dial indicate.
      Was there that much difference in the drilled and tapped mounting holes in the back of the block from engine to engine?
      George King
      Grants Pass, Oregon
      63 GT Hawk
        This is a very interesting question since the 6 cyl bellhousing doesn't have dowel pins for alignment. The bolt holes in the bellhousing are bigger than the bolts. Also you have to use a 169 bellhousing plate. The 185 won't work.
        Claude Chmielewski
        Studeski
        http://www.studeski.com
        Fillmore, Wisconsin
        47 M-16 Truck
        53 Commander Regal HT
        53 2R5
        60 Lark VIII Convertible
        60 5E7 Champ pickup
        62 5E7 Champ no box
        62 GT Hawk 4 speed
        63 Lark VI parts car
        63 GT Hawk R2 4 speed
        64 Commander Wagonaire
        64 Daytona Convertible
        50 Champion Regal (parts car)
        36 Dictator
        36 Dictator in pieces
          What Studeski (Claude) said, George. BP
            Guess that answers my questions,
            Thank you Bob & Claude
            George King
            Grants Pass, Oregon
            63 GT Hawk
