Took off the heads and pan on my 57 Golden Hawk's 289 today (so an out-of-town buddy could take a look; the rebuild is a year or more off yet...)
It APPEARS that
a) engine was recently rebuilt; very clean (what you see is untouched by us, everything looked great)
b) original Stude pistons? no 'oversize' stamps on them and appear to look like those shown in the factory manual; and hardly any ridge, as mentioned by others, likely to get by without a rebore this time too.
How about the valves? They are Eaton; is that what Stude used originally? Will eventually take everything apart (was itching to keep going today!) but curious if the valves have been replaced. I forgot to check and see if there were hardened seats, but I don't think so, sure doesn't appear to be in the photo.
Also from the "010" stamped into the crank counterweight, I assume the crank was ground once.
Only 60 some thousand miles on odometer, but cable broken so who knows..... I wonder why it got rebuilt in the first place, most everything else looks original so why would the crank get reground, if the pistons and valves(?) were ok?
So far, the only things I see that I'd for sure replace are the push rods (if available?) as they have some flat spots, and perhaps a set of head bolts, just out of prudence (I don't like reusing headbolts if new ones are available.) And then hardened valve seats......and rings.
But final dis-assembly and micrometers will tell a lot more of the story of course. AFTER the blasted sheet metal work gets done :-(
It APPEARS that
