I have a 62 hawk with a 259 that runs ok just lots of leaks and blow by, its puffs out the breather. I was under the hawk and started to wonder. If I could drop the oil pan while the engine was in the car. Perhaps I could drop the exhaust it needs repaired any way, some steering linkage, then the oil pan. After removing the intake and heads could I push the pistons out put on new rings, gaskets that 4 barrel ...... and be good to go. How about the rear seaL. I did this with a 6 cylinder jeep years ago worked ok ( it had a 2 piece seal)...
In car piston removal
Yes, it can be done.
No, I wouldn't ever do that again.
Maybe, just replace the valve stem seals and drive it til you can afford to do it right.. Search for a good 289" and build it out on the bench and replace the 259".
jack vinesPackardV8
I say, absolutely not. Chances of it being successful are extremely slim.
This is not a tractor; it's a very precision unit, where cleanliness, exact measurement, and perfect assembly are required.
Don't do a cob job. You're going to do a lot of labor and spend a lot on parts as it is- go the extra mile, or risk wasting your parts and time.Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
jack vines
JoeLast edited by irish; 12-28-2011, 08:17 PM.sigpic
1962 Daytona
1964 Cruiser
And a few others
One of the problems with doing that is, the improved compression at the Rings just burns more Oil at the top end without new Valve Guides and Valves (and Valve Grind if needed).StudeRich
Originally posted by StudeRich View PostOne of the problems with doing that is, the improved compression at the Rings just burns more Oil at the top end without new Valve Guides and Valves (and Valve Grind if needed).
JoeLast edited by irish; 12-28-2011, 08:32 PM.sigpic
1962 Daytona
1964 Cruiser
And a few others
If it smokes on decelleration and then when you give it gas, and smokes when you start it after it
has sat for a little while but clears up some, it is probably valve seals. It it smokes all the time it
can be valve seals AND guides .. and rings too. What did a compression test tell you? Did you do
one yet? It can tell you a lot. Low all around cylinders, that improve with a shot of oil inside, will
tell you its rings, no chance tells you its worn valves. As far as memory tells me.....
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
Why is it every time some of our forum members ask questions that might in the long run require getting something big sent and I go to their profile to see where they live I find nothing? how come no one wants others to know where they live, when that happens I just move on and say I guess they really don't kneed it. I think there is more people with out a good pro file than one with a good one.Candbstudebakers
Castro Valley,
California
Originally posted by candbstudebakers View PostWhy is it every time some of our forum members ask questions that might in the long run require getting something big sent and I go to their profile to see where they live I find nothing?
I think some just don't make the effort, but some think there will be some kind of security issue, which is unfounded.
Maybe there's a software way to make these two items a requirement to register. Even better, a way to automatically lock existing accounts until the required info is added. Name and city/state are NOT too much to ask.Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Originally posted by Bob Andrews View PostI say, absolutely not. Chances of it being successful are extremely slim.
Easy Bob...... I agree with you that in car rebuilds give mixed results at best. If you do a cob job on a "tractor" you will get exactly the same results. They too are more precision than most would expect. Most ag engines have even closer tolerances than automotive engines.
Still good advice, do it right the first time.1962 Champ
51 Commander 4 door
Originally posted by Kurt View PostEasy Bob...... I agree with you that in car rebuilds give mixed results at best. If you do a cob job on a "tractor" you will get exactly the same results. They too are more precision than most would expect. Most ag engines have even closer tolerances than automotive engines.
Still good advice, do it right the first time.Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Even if I were going to do an "in-car" overhaul...I would still remove the front clip. It makes everything so accessible. You would still have to elevate the chassis and work from underneath, but all the other stuff required would still be much easier.
The biggest drawback is not being able to rotate the engine as you would on an engine stand. I have done it both ways. The older you are, the more likely the engine will come out and be placed on a stand. (At least, that's the way it worked with me!)John Clary
Did a "quicky" rear main seal and main bearings on a '63 Hawk - Did get some more use out of it. Was it worth it?? Probably would have run just as well without the work (the main started leaking again in a couple months). Did get a very sore neck and an "enriched" vocabulary - would not try it again.
Paul TK
