Three speed swaps?
  • Three speed swaps?
    I know everyone out there seems to be installing T-10s, T-5s and everything else under the sun but has anyone figured out any three speed swaps.. for example what could I use if I wanted to get a three speed that had a syncro first gear.
    Since I am working with a V8 would a change of bellhousing allow me to use a Saginaw three speed or would a Ford three speed toploader work.
    As it is I am rebuilding a T-86 using a T86 and a T-90 Taxi transmission to move my shifter to the floor.
    any thoughts?
    Jeff T.
    "I'm getting nowhere as fast as I can"
    The Replacements.
    \"I\'m getting nowhere as fast as I can\"
    The Replacements.
    Greetings, Jeff T.
    The '64-65.5 Ford toploader three-speed full-synchro has the same bolt pattern as the Stude Borg-Warner. IIRC, the input shaft is a bit shorter, so you will need an extended pilot bearing.
    There were two input shaft versions. The big-block is very rare - I have never actually seen one. The small-block is relatively common. The tranny is hell-for-stout. A Stude will never break one.
    The Saginaw, by comparison is about the same strength as the T-86.
    thnx, jv.
