A well set up Blanchard grinder will leave a flat surface. Any machined surface will be less flat and probably not a match for the head surface.
How Many Holes???? (Stude V8 Torque Plates)
jack vinesPackardV8
Perhaps a little lapping compound and four hours of floating the head on the block would mate them.
Surface finish is also very important too. It's possible for mating surfaces to be too smooth. The higher the temperatures and combustion pressures, the more the head gasket needs some tooth in the head and block surfaces to help hold it in place. For many years, most aftermarket gasket manufacturers said a surface finish of 55 to 110 micro-inches RA (roughness average), or 60 to 125 RMS (root mean square) is acceptable for conventional gaskets.
FWIW, back in the bad old days, Permatex paid Bobby Allison to build a NASCAR Grand National car without gaskets, using only their products for sealing the water, oil and lubricant containment. The only exception was head gaskets were used. Too large an area, too much combustion, oil and water going on there.
jack vinesPackardV8
