Power Steering Problem.
  • Steering: Power Steering Problem.
    I know this is a technical question, and the steering is in a '47 M5, but it's to do with a Ford Aero power steering servo and a GM pump. I recently took delivery of the M5 from Fred Martin in Atlanta, great guy, and a great truck. I encountered the problem getting it on to the trailer from the shippers, the steering is very stiff, I mean REALLY stiff, almost as if it's locked. I emailed Fred and he said he had it 'freeze' up on him twice before, and had intended to replace the GM pump with a Ford pump, (that he kindly packed in the truck for me).
    But I was thinking, before I got changing brakets and hoses etc, there must be some simple, after all it;s a hydraulic pump same as the Ford pump. Have any of you got some ideas, maybe a pressure problem that could be fixed with a different relief valve spring ???
    Matt
    Brisbane
    Australia
    Visit my Blog: http://www.mattsoilyrag.blogspot.com.au/
    Does it stop doing it when it is warmed up? If it does it has "morning sickness" and needs a new R&P box.
    Terry
      Terry
      I've only driven it a very short distance, the engine was warmed, but probably not the steering system. From what the previous owner said it sounds like temp doesn't play a part in the problem.
      I'm going to copy this thread over the Stude Specific section for those that don't read the Stove Huggers section.
      Matt
      Brisbane
      Australia
        So we are dealing with a Ford Aerostar Van setup here? That limits our knowledgeable info somewhat.
          Matt, The GM pump pressure is greater than needed for the Ford R&P. Click on the links below for a solution.
          http://www.summitracing.com/search/B.../?autoview=SKU
          OR
          http://www.speedwaymotors.com/Mustan...-GPM,5852.html
            StudeRich - We don't have Ford Aero's here, so I guess you would be right. I'll email the previous owner and ask some more questions.
            31 Streetrod - Thank you, it looks like you may have solved my problem. I'll pull the pump before I go getting excited and order the parts. 12000 miles is a long way to change them if they're the wrong ones ;-)
            (Both web sites say it's for a GM pump & Mustang steering set up, will this still be the same fix for a Ford Aero steering?)
            Thanks guys, I knew the Stude brains trust could help.
            Matt
            Brisbane
            Australia
