bendix
  • Electrical: bendix
    should the drive gear of the bendix be in the fully extended position when at rest?
    Bench testing before I install
    Gallivan
    57 Golden Hawk
    Golden, CO
    I believe that normally it would be retracted but if it's extended (as happens when testing) it will stay that way until the engine spins it. You can install it with the Bendix extended and it will be fine.
    Jeff DeWitt
    http://carolinastudes.net
      If you are bench testing the bendix gear should retract when you disconnect the positive cable
        Have to disagree with jallen - once the Bendix is extended, it will remain out unless you install it on the car and fire the engine with it.
        However: Forum member Flashback posted a way to manually retract the Bendix in this thread.
          There's more than one kind of starter drive, and right or wrong i've always called all of them 'Bendix'. Some retract automatically and some don't. The ones that don't, the flywheel will kick it back once it starts. It can be installed either way.
          Another point of confusion that comes up all the time is whether you have to have the polarity correct for bench testing....it doesn't matter, since a starter is series wound, it can only spin one way. Try it both ways, you'll see. You would have to switch the brush leads to make it go the opposite way. Same applies if you convert a pos ground car to neg ground, the starter doesn't care
          1947 M5 under restoration
          a bunch of non-Stude stuff
