Display temperature doesn`t work
  • Electrical: Display temperature doesn`t work
    It always says cold, where do I find the sensor? (Lark 63)
    Thanks
    Walter
    80 Fiat Spider
    63 Lark Regal 4 Dr. sold 2015
    60 Hawk sold 2017 in England
    56 Golden Hawk
    56 Corvette (John Cougar Mellencamp's C1)
    68 Volvo P1800S
    56 Jaguar XK 140 DHC
    http://www.speak-to-doc.de/oldi/
    V8 or six?
    V8's on the back of the left hand head, almost against the firewall.
    six is somewhere on the left side of the head, toward the back.
    Left is as you are sitting in the drivers seat, on your left.
      Thank you Tom, I see it (6 cylinder), how can I check the water temperature sender, or just buy a new one?
      Walter
      80 Fiat Spider
      56 Golden Hawk
      68 Volvo P1800S
        Make sure the wire has a good contact. remove the wire, polish the contact surfaces, put it back together again, get the engine hot. If it doesn't work, check with the Studebaker vendors listed elsewhere on the home page, someone's sure to have one.
          The temp gauge in our Flight Hawk wasn't working when we got the car. The temp sender is a variable resistor that lowers resistance as it gets warmer. We tested ours by grounding the wire from the temp sender and checked the gauge in the car. It almost pegged, so we replaced the sender.
            Hi Walter, what Fred said. You also might check the actual engine temp by getting an infrared temp gun and see what your actual eng. temp. is. There getting really cheap at H. F.
            Brian
              check under the dash for a pulled wire from the gage itself, or possibly the 2 wires were re-installed backwards. Your wire will be orange.
