Front and Rear Seals on my 1963 289 Full Oil Flow Studebaker Motor
  • #16
    Originally posted by radiotech View Post
    Also make sure the PCV system is clear and operating, if it's equipped with one. If the system/valve is plugged up it could cause excessive crankase pressure to build up and create leaks where none really exist!
    I agree. Though the PCV system on your car only consisted of a road draft tube and a breather cap. The air draws in thru the breather cap and is drafted out the road draft tube when the car is moving. When running while sitting still it just goes out either/or of those two locations.
    • #17
      Make sure you find the source of the leak first...get a decent quality black light
      http://www.homedepot.com/Electrical-...atalogId=10053
      and some UV dye
      http://www.autozone.com/autozone/acc...equestid=65000
      Clean everything up well with a pressure washer and some degreaser, add the dye, drive it around for about 20 minutes/miles. That'll go a long way to helping you find where it's leaking.
      • #18
        Thank you for the Links
        and some UV dye
