I've read and re-read every post I could find (and looked at the photos), but it is always different when your face is pressed up under the rusty mess looking at it with your back on the cold concrete floor... (in Minnesota).
(re: '57 GHawk), now that my floor is cut out, spot-welds are cut out of the support arm EVERYWHERE EXCEPT UNDER THE COWL PILLAR, do I "simply"
a) lay under the car and cut UP into the cowl pillar and remove those spot welds holding the body support arm to the pillar
b) since I've already snapped off all three bolts (two in support, one from 'bat wing' to body but THROUGH the support, I think?) the frame support should be 'free' to be removed, right?
BUT, won't I need to loosen (break??) other frame bolts to jack up the body off the frame enough to wiggle/pry/hammer that frame support out from under? It looks pretty wedged in there; I can barely see the remnants of the original rubber supports, it is pretty much metal to metal contact in most places or filled with rust perhaps; sure can not see light between it anyway, and anticipating a fight to get it maneauvered out and the new Classic support re-positioned IN.
c) when the new support is "in", is there anything critical for positioning except that the outboard 'square' fits in the pillar box, and that I have the same spacing from transmission tunnel to the door (my choice for a 'check' measurement')? The holes for the two bolts are huge, so lots of room for it to move. Seems it doesn't matter where that support is as long as it fits the pillar box and can be spot-welded to it, and those big holes line up with the frame holes for the two bolts (looks like I need to drill one hole on the outboard end of the support, though until I get the old one out, hard to really tell what is what, maybe that is separate and attached to something else under there...)
Oh, to have a prisitine car to roll under and check visually back and forth instead of guessing what is hidden by rust and crud over the years. :- )
PS: the photo shows the support BEFORE I drilled the remaining spot welds and broke off the three bolts Sunday :-) Otherwise that is how she sits today.
