Molasses rust removal?
  • Body / Glass: Molasses rust removal?
    There is an Australian on YouTube that soaks rusted steel panels in a 1:9 ratio of sulphered molasses and water for about 2 weeks, then uses a pressure washer to remove the sludge. It appears to work. Has anyone here used this method?
    \"Ahh, a bear in his natural habitat...a Studebaker!\"
    51 Land Cruiser (Elsie)
    Jim Mann
    Victoria, B.C.
    Canada
    Pretty well known. Seems to work as advertised, but I haven't yet tried it. There used to be someone that came to the Meets selling a molasses-based product, but I can't remember the name of it just now.
    Proud NON-CASO
    Romans 15:13
    Deuteronomy 31:6
    Proverbs 28:1
    Illegitimi non carborundum
      Is Molasses that much cheaper than Naval Jelly?
        I saw a thread on a Datsun site about this. The guy bought the molasses at a feed store, not the store bought molasses. Cheaper than Naval Jelly and cleaner, not as toxic. Vinegar will work as well, just takes a long time.
        http://youtu.be/PhXcwRyGVsU
        Here is a link I googled
          Yes I have used it for years. It is called Treacle. Keep it in a plastic air tight container. I have not seen it remove paint yet. It will clean the smallest pits. Neal
            There's also beet juice rust remover...
            I remember Max Corkin (IIRC) selling it at Reedsville in 5 gallon buckets.
            Also, do an 'advanced search' here for 'rust removal' (Titles Only)... Active subject for all of Stude eternity....
            (That's why 'good' topic headers have such relevance)
            http://forum.studebakerdriversclub.c...earchid=628095
              FWIW, molasses is really nasty stuff to work with. I wouldn't use it again if you gave me a bucket. Don't ever leave a batch for a long time in warm weather!
              I've used molasses, beet juice, vinegar, and Evapo-Rust. This last, sold at Harbor Freight is by far the best liquid method.
              Read up on electroylsis. It is my preferred method for rust removal. Many detailed instructions available with a web search.
                Electrolysis is my choice, for parts that will fit in a 5 gallon bucket, anyway. I kept a bucket going for a couple of months while re-habbing my '55 LC, everything from hose brackets to kingpins. A couple of pieces did one end then the other. I used a coat hanger wrapped around the inside of the bucket for an (anode or cathode) (had to replace it every couple of days) and a piece of brake line across the top of the bucket for the other -ode, connected to a 12 volt battery charger, forget which way, but change polarity if the coat hanger bubbles.
                Oh Yeah, put 1/2 cup washing soda in each bucketfull.
                Last edited by Tom Bredehoft; 11-22-2011, 10:25 AM. Reason: to finish the formula.
                  I have tried the electrolysis method on smaller pieces. It seemed to work fairly well but required a lot of messing about, cleaning the electrodes etc. to keep the process going. It's also somewhat line-of-sight so it doesn't fully get all the areas unless you flip the pieces ariound.
                  I like the idea of throwing something into a bucket of molasses brew and just leaving it for a week or 2. However, I am impatient and would likely pull it out every day to see how it was going. A watched kettle never boils!
                  Cheers,
                  Jim
                  Jim Mann
                  Victoria, B.C.
                  Canada
                    Thanks, Jeff.
                    Sometimes, I don't do a search because I'm also looking for a conversation as well as information. I am not able to attend most of my local chapter activities so I enjoy a chance to converse with strangers from all over Studedom.
                    Cheers,
                    Jim
                    Jim Mann
                    Victoria, B.C.
                    Canada
                      I like the electrolysis method. I have been using a 30 gallon plastic garbage can which will take some fairly large pieces, but I am getting a plastic 55 gallon drum so I won't have to change the larger pieces around as much.
                      I use pieces of pipe hanging from the top of the container for one connection and they last quite a while. I usually hang the part from coat hanger wire with the other connection attached.
                        I don't recall Max selling it; maybe. There was another fellow demonstrating and selling at York. Packaged dry form in bags.
                        I guess any method you use is going to create a mess of some sort.
                        '33 Rockne 10,
                        '51 Commander Starlight,
                        '56 Sky Hawk
                          I use the electrolysis method with rebar as the -ode for medium sized stuff and Evapo Rust for the little stuff.
                          Terry
                            Isn't a beadblast cabinet easier?
                            Good Roads
                            Brian
                            Brian Woods
                            woodysrods@shaw.ca
                            1946 M Series (Shop Truck)
                              I picked up a large vibratory tumbler...used mostly for fasteners and smaller items....it isn't for cleaning, more for finishing the items after soaking and degreasing them...I use it with walnut shells...another nice system to work on things while you tend to something else...
