No engine compression in 2nd in a T-86..
  • No engine compression in 2nd in a T-86..
    Guys-
    Is it normal not to have much engine compression braking in 2nd gear in this T-86 in my 2R11?
    Seems like it just wants to coast...where in the ol truck trans it definetly had engine compression that acted as a brake...
    Different to drive now.[]
    dan0
    Herd:
    06 Jetta TDI
    1941 M15
    1953 2R11
    2001 F-350
    1989 Caprice
    Deere's:
    67' 112H
    88' 332
    Did you swap from a straight three speed to an OD trans? If so, perfectly normal. There is no engine braking until the OD engages. If you anticipate a need for engine braking, lock out the OD before you start out.
      Greetings,dan0,
      Actually, if the OD is working properly and you are in third gear with the OD engaged and downshift to second, you will have compression braking down to the OD disengagement point, usually about 28mph. Just when you are coming up on that downhill hairpin turn and you are busy with steering, the OD will disengage and you sail off into the weeds.
      As N8N says, lock out the OD if you don't want to play.
      thnx, jv.
        Guys-
        I have not enen connected the OD Sol yet...just aint used to coastin' so much...where's my eng compression...?
        Big difference ..I've been double-clutchin' for nearly 6 yrs!
        dan0
        Herd:
        06 Jetta TDI
        1941 M15
        1953 2R11
        2001 F-350
        1989 Caprice
        Deere's:
        67' 112H
        88' 332
          quote:Originally posted by dan0
          Guys-
          That won't stop it from free wheeling IF the overdrive handle is pushed in. Pull it out and try it. If you haven't hooked that up yet, go under the car and move the lever the OD cable attaches to forward. That will take it out of OD and you should then have a normal 3 speed trans (with engine braking).
          Bellingham, WA
            What Dick said. The solenoid does nothing until vehicle speed is about 28-32 mph. Below that speed with the control pushed in, the vehicle will freewheel. Shifting down to 2nd gear below that speed won't do anything. The up side is once you are rolling you can change gears without using the clutch pedal until the solenoid engages.
            Terry
              Guys-
              Correct; I don't have the cable attached yet[:I] Do I understand correctly I have OD now with the lock-out lever pushed aft?
              I know, GREENHORN![]
              dan0
              Herd:
              06 Jetta TDI
              1941 M15
              1953 2R11
              2001 F-350
              1989 Caprice
              Deere's:
              67' 112H
              88' 332
                yep
                Terry
                  Guys-
                  dan0
                  Herd:
                  06 Jetta TDI
                  1941 M15
                  1953 2R11
                  2001 F-350
                  1989 Caprice
                  Deere's:
                  67' 112H
                  88' 332
                  Unless the solenoid is connected and working, you don't have overdrive, but you do have free-wheeling. The rear-most unit in the overdrive case is the over-running (sprag) clutch, which allows the engine to drive the wheels, but won't let the wheels drive the engine. It is needed to take the torque load off the driveline so the solenoid can shift the overdrive in or out. When you pull the lockout handle out (lockout lever forward), the sun gear is moved back, and effectively bridges across the over-running clutch, locking it up. Useful for mountain driving!
                  In a normally-operating overdrive, freewheeling is only in effect in direct drive, below the OD cut-in speed. Once the overdrive engages, you have two-way torque transfer in the transmission again. You won't see much engine braking in 3rd OD, because of the gear ratios involved, but it IS there.
                  Incidentally, when you shift to reverse, the overdrive shift rail is pushed back by a cam on the first-reverse detent sector, effecting the same lockout action as the manual lockout cable provides. Were this not so, you'd have no reverse, as the over-running clutch can't transmit torque in reverse. It's always good practice to leave an OD-equipped car in Reverse when parked, so it won't roll away.
