OK, I need help from the Stude refurb genii
  • Body / Glass: OK, I need help from the Stude refurb genii
    I've just replaced the rubber and window guide on my Champ wing vents. They are both still on the coffee table while I watched another pass*less Tebow exhibition!
    The puzzle for me is neither one will close the last 3/8 inch. They bind at that point. After hours of examination and open/close attempts, I cannot identify the point of bind that is stopping them. I have exercised them hundreds of times, examined, tried to pinch paper to identify the bind with no luck .... hence they are still on the coffee table where I used them for stress relief during at least 2 games.
    I welcome any ideas from the experts as to how to identify where the bind may be.
    Thanks....
    The ones I have had that were stiff to close I backed off the nut on the spring tension at the upper part of the vent assy. Lube all the pivots with a white grease (luberiplate), maybe even spray some silicone in first then grease & see if that helps.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
      Put a little K-Y Jelly on the rubber and it should slip right in.
      Jerry Forrester
      Forrester's Chrome
      Douglasville, Georgia
        Jerry
        That's way to simple to work.
        Klif
        55 Speedster/Street Machine
        63 Avanti R2
        64 Convertible R1
          Gosh Jerry, how did you ever come up with that idea?
          Paul
          Winston-Salem, NC
            Paul
            Winston-Salem, NC
