First off a little background. I copied and blew up a "63 Studebaker" wiring diagram but the colors listed on the print do not exactly match what I see on the switches. I have both 63 white rocker switches and black 66 rocker switches. I am using the black 66 ones. All the wiring colors on the switches match between the 63 and 66 ones. They all have stubs of wire still attached to them from when they were cut out of the original wiring harnesses. The diagram seems to be off,but oh well.
My questions are:
Does the headlight rocker switch carry the entire load of the headlights? If it does I think I am going to install relays to carry the load instead of running it all thru the switch.
Is the heater motor a 2 speed affair or just 1 speed? If it is 2,HOW did Studebaker get both speeds? I do not find a resistor in line anywhere.
Same with the wipers. 2 or 1 speed and how?
THANKS!
My questions are:
THANKS!
