2R Column Upper Shift Lever "floats"
  • 2R Column Upper Shift Lever "floats"
    All-
    Should the upper link on a column shifter (2R11 Commander 6 T-86) be free to rotate on the shaft?
    Seems like it should be affixed to something; welded, pinned...etc
    dan0
    Herd:
    06 Jetta TDI
    1941 M15
    1953 2R11
    2001 F-350
    1989 Caprice
    Deere's:
    67' 112H
    88' 332
    You're talking about the cast metal thingy just under the steering wheel? It has a big screw that tightens and causes the part to clench onto the top of the steering column tube. If that's what you're talking about, find the head of that screw (it's inset into it's hole) and tighting it good. That should stop it from flopping around.
    Miscreant adrift in
    the BerStuda Triangle
