Well once again I need so of your expertise. And as always your input is appreciated in advance.
My left rear E-brake cable is frozen in the tube going into the backing plate.
I got the ball end of the cable out of the E-brake actuating arm on the rear shoe, so the cable is free from the shoes. 2 issues here though, 1} there is a tube inside of the backing plate tube that makes the opening smaller and closer to the cable diameter. But this does not allow the ball end of the cable to come thru the backing plate inlet tube.
How does the cable slide out of the BP inlet tube? Does this inner tube come out of the larger tube to allow the cable with the ball end to slide out?
Issue 2} If the inner tube does come out, how do you get it out?
The inner tube is flush with the end of the outer tube so I can not grab it with pliers and pull it out. I dont see a way to get anything up inside it in the inseide area of the inlet tube to push it out.
And a 3rd issue is it is all frozen solid and I have been PB blasting it for days and I still cannot get it to budge. I have tried going up to next guide closer to the cab and standing on the cable to pull on the cable with my 200# of belly fat and even bouncing on the cable....not a budge.
Any ideas folks?
I feel like I need to go inside the backing plate area and drive the inner tube outward but I just think anything I try to do that with will just wedge in there and also damage the cable and the BP inlet tube.
HELP...
Any ideas folks?
HELP...
