Reluctant Woodruff key
  • Reluctant Woodruff key
    I pulled the timing gear off the front of the camshaft without any trouble, but now the Woodruff key doesn't want to come out of the groove on the camshaft. I'm afraid to get too forceful with it, so does anybody have any suggestions or tricks I should use here?
    Jim Beckman
    1951 Commander Starlight
    Often times I've found if you use a punch at one end of the key and strike it downward with a hammer, the opposite end of the key will lift up. Any damage from the punch can be removed with a file and if the key is too bad for that, you better spend two bits for a new one.
      Jim Beckman
      Jim, tap one end with a brass drift and hammer. When the other end pops up, get up under it with either a smaller brass drift or a small screwdriver to continue tapping it up.
      Paul
      Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
      Paul
      Winston-Salem, NC
        OK, I got it out. I had to use a small cold chisel to get
        a good enough grip on it after I popped one end up, so the
        key needs to be replaced, but I guess that won't break the
        bank.
        Thanks for the advice, guys.
        Jim Beckman
        Leonardo, NJ
          I've also sanded keys a small amount on the sides, using 220 grit wet-or-dry. You definitely don't want to sand them so much they are loose, but a small amount of sanding on a tight key helps.
          1953 Chev. 210 Convertible, 261 6cyl w/Offy dual intake (But I always did love Studebakers!)
          1995 Dodge/Cummins Pickup, 250 HP, 620 Ft. Lbs. of Torque, ATS trans.
          Robert Rausch
