Nvonda, Terrific website, thanks I really liked it. I think I am as close to understanding this now as I can get. Just to review: Keep in mind, engine is in car. I plan on a dry run of putting up the clean filler block, dry gaskets, and pan. That way I will see what I think is correct.
You said a great idea, put the side pan gaskets in place with my silicone and hold them in place with the pan. Once dried, remove the pan, then attach the new front cork gasket to the filler block. When dried, install the filler block with gasket and compress that in place, it takes compression because the newly installed side gaskets go UNDER it?? If I have that all correct, put silicone on the rear cork gasket, press it into place, put silicone on the surfaces of the side gaskets, the front filler gasket and the rear cork gasket and put up that oil pan..................thank God! I know this is anal but I have read many different versions and inputs and hope one of you can tell me this IS a good enough approach. Thanks in advance.
Gregor
Gregor
