Brake Question
  • Brakes: Brake Question
    I am using the Turner disc brake conversion with Monti Carlo calipers in the front and an 8" ford in the rear.
    My 8 " for is a little odd from the ones I normally use, as it has 2 1/2" x 10" shoes.
    It calls for 7/8" bore wheel cylinders rather than the common 15/16" cylinders I normally use. As I plan to use a Villager master cylinder with a remote resevoir so I don't have to go under the floor to fill it.
    Does anyone have any thoughts on this combo??
    I know Junior used it. And Junior I have pm'd you re your rear wheel cylinders and shoes??
    Thanks for any imput here.
    Good Roads
    Brian
    Brian Woods
    woodysrods@shaw.ca
    1946 M Series (Shop Truck)
    Brian, according to the O'reilly auto parts website, the wheel cylinder bore is 3/4" and the brake shoe size is 9.5 x 2.06" for s-blazer rearend. Hope this helps, will locate photos and part nos. of the front calipers I used and the mod I had to make on them. Junior.
    1954 C5 Hamilton car.
      Junior
      The part number for the T10 calipers is different from that of the Monte Carlo calipers recommended by Turner.
      Is there a reason you used the T10 over the Monte Carlo??
      Brian
      Brian Woods
      woodysrods@shaw.ca
