53 Grill script install question
  • Body / Glass: 53 Grill script install question
    I recently bought the script for my 53 grill bars, along with the clips.
    In fact 2 sets of clips in 2 different sizes.
    I think they're called barrel clips
    One set seems too big, won't fit in grill bar , and just rattles around on script posts.
    The other too small,which won't allow posts to slide in.
    I thought the small ones might stretch, but for them to stretch enough to take the post, the holes in grill bar would have to be drilled larger than the head of the clip, so that won't work.
    What am i doing wrong, can someone please tell me?
    I suppose i could glue them, if thats the answer what is a good glue to use?
    Thanks
    John
    Probably copper, nickle and chrome build up and closed the holes up somewhat. Do the pins fit into the holes without the barrel nuts? If so don't use the barrel nuts, use the small, flat clips that press onto the pins.
    Jerry Forrester
    Forrester's Chrome
    Douglasville, Georgia
      Hey Jerry
      Yes the the chrome did fill holes somewhat, but i drilled those out already.
      I can get the pins in the holes now. I had an oem bar to get the hole dia, but even that dia. is too small, the new SI script pins are bigger than the old script, so holes needed to be bigger than stock as well.
      Are the small flat clips a stude piece or just a jobber piece?
        I believe my original scripts were installed with the flat clips. That's what I used when re-installing.
        The barrel clips were generally used when you had no access to the pins, ie. rear fenders and trunk script.
        '33 Rockne 10,
        '51 Commander Starlight,
        '56 Sky Hawk
          Originally posted by johnod View Post
          Hey Jerry
          I know you can get them here...... http://www.restorationspecialties.com/
          But you can probably also get them from SI.
          Jerry Forrester
          Forrester's Chrome
            I've been running around for 9 years with plastic 'clips' holding my scripts on. I took an old butter tub lid, cut it into half inch squares, punched holes in the middle of each one with an awl, and pushed them on the pins, It works a treat, and they are removable, and the cost is reasonable.
              That's a great idea Tom.
              Jerry Forrester
              Forrester's Chrome
                Thats a good idea, I think i can figure that out with some thought, and a computer program.
                Thanks
                  Once you get the scripts fitting in the holes, put a very sparing amount of silicone RTV at the holes, slip the script on, tape it down flat if needed, and they will stick on like shiite to a blanket.
                    I have never used clips on these. I just used some adhesive/glue on the clips. They are usually a tight enough fit that they would probably stay on with nothing.
                      Are all of these tips applicable to the "V-8" emblem on the side as well, or are those too heavy?
                      '53 Commander
                      Art Morrison chassis
                      LS6 ASA/4L60E
                        Problem with the emblems on the side of the fenders, you can't get access to the pins unless you remove the fender from the body.
                        Those emblems, and any script on the trunk lid require the barrel clips mentioned earlier.
                        '33 Rockne 10,
                        '56 Sky Hawk
                          New quarter panels did not come with the holes for these. I have always left them off. It is a cleaner look, easier to clean and most people do not notice them missing. The main reason for leaving them off is that Bob Bourke did not want anything there.
                            Stealing the thread a bit! Does anyone have a set of NOS grill scrips for my53 C/K grills. I thougth they would be something I could find easily on ebay. But not so easy?? Have been watching for over a year!
                            Pleaase PM me if you have some you might be interested in parting with.
                            Good Roads
                            Brian
                            Brian Woods
                            woodysrods@shaw.ca
                            1946 M Series (Shop Truck)
                              Good Roads
                              Brian
                              You should state if you want "Champion" or "Commander" for the left grille.
                              I will look when I get a chance.
