radiato hose part #
  • radiato hose part #
    Looking for a part # or application for a upper radiator hose. 54 coupe with a late 289, 2 bolt t-stat housing. The radiator is the original 54 design.
    Thanks
    Russ
    57 SH (project)
    60 Lark VIII 2dr sd (driver)
    53 2R6 289 5SpdOD (driver)
    57 SH (project)
    When I tried to hook the radiator hose up on my 52 Commander with a 64 289 engine, I found the radiator inlet smaller than the outlet on the engine. I couldn't find a hose that would fit, so I had the radiator shop put a larger nipple on the radiator. Since I had them recore it before, they didn't charge me to do it.
    Leonard Shepherd
    http://leonardshepherd.com/
      A later radiator will not work as 53-55 radiators are shorter than the later ones.
      does this help?
      http://members.cox.net/njnagel2/ther...hermostat.html
      Alternately, a '55 through ?? water manifold will fit on the later engine. a pre-55 one will not work as it will not clear the die cast timing cover (earlier cars had a sheetmetal cover without a fuel pump mount.)
      hope this helps
      (slowly restoring my web site a little at a time)
